The driver interface is not consistent
Using NIDAQmx v7.4
Why does the method DAQmxGetAIRngHigh fail on a simulated PCI-6143 device?
(Requested value is not supported value for this property.)
DAQmxResetAIRngHigh works and is called just before DAQmxGetAIRngHigh.
Why does the method DAQmxGetAIConvRate returns error on a simulated PCI-6110 device?
(Specified property is not supported by the device or is not applicable to the task.)
-cpede
(3,354 Views)
Hi
The DAQmxGetAIRngHigh function works perfectly on a simulated device on my end. I did receive an error when running a modified CVI example because the default requested min and max values were -10V and +10V. Are you sure you weren't seeing this error instead? I. Make sure that you change the input limits to +-5V to avoid the error we're discussing.
The DAQmxGetAIConvRate fails on a PCI-6110 (and all S Series devices) because there is no convert clock. The S series boards have independent ADCs for each channel and therefore no convert clock.
A Meister
NI DK
(3,334 Views)
This reply looks very familiar Meister. 😉
Message Edited by Tom W. on 06-27-2005 07:26 PM
Tom W
(3,323 Views)
