I have a PCI6013 and I use a SCB-68 terminal block.  I have to aquire 5 thermocouples and two captors (flow rate meters).  I have to use differential mode.  Here are my questions: Why do I get different voltage value from the thermocouple when i use different values of bias resistance?  I used 10k and 75k and I get different values.  How to choose the right value of resistance?  Can't I just use a wire instead of a resistance?.  Is it necessary to read the zero offset for ground reference?  I yes, I do I do that (between which channels?  Next: When I connect my captors, the voltage value from the thermocouple changes.  Do I need to use a bias resistance also for those captors?
