Time loop with DAQ 6008
Hi All,
I am working on placing Time loop structure around my DAQ assistant to get loop rate to 5KHZ. As you know if I would like to increase my iteration speed to more than while loop, I need to go for Time loop. Currently after replacing while loop to time loop around my DAQ, I found that my loop is not executing also I can not stop my running VI. I have DAQ 6008 with properties set as continous sample mode with 1000 samples to read with 1K Hz of sample rate. Can you kindly let me know where am I doing mistakes ?
Thanks in advance,
Nick
(3,486 Views)
Accepted by topic author Time loop
Answered here.
You do not need a timed loop.
(3,480 Views)
