03-25-2008 02:10 PM
I need to get the Windows XP system time when the left mouse is clicked while the cursor is placed over one of the control buttons created in Labview. The system time and the proper button description pair will need to be sent over the LAN to a National Instruments FPGA module (NI 7833R) for data logging. The NI Labview software was used to place button on the screen VI. Again, the pair needs to be generated when the left mouse button is clicked while the cursor is placed over the Labview button.
I am sorry to say that I am very new at this, so I will not understand a very technical explanation. Don
03-26-2008 09:13 PM
03-27-2008 03:01 PM
03-30-2008 11:58 PM
04-01-2008 02:59 PM
Eli,
I think you understand me correctly. However, to understand your suggested solution I think I need more NI training. I have only had: an Intro to LabView 6 hours CD- Sep 2003 edition, and attend a one day workshop called "Build a complete Automated test system in 3 hours using LabView". The courses I am currently thinking about taking in the next several months are: LabView Basics I, LabView Basics II, LabView FPGA, and Data Acquistion and Signal Conditioning.
My questions to you are:
In order to gain the knowledge to understand the solution you suggested above, are these NI courses the best way to spend $3500?
Or, in your opinion, are there other courses I should consider?
Thank you so much for your help,
Don
04-02-2008 11:52 AM
DL Novice,
I think it is a really good idea to consider formal training. I realize that
these courses can be somewhat pricey, but the benefits in the long-run far outweigh
the costs. The LabVIEW Basics I & II are pretty extensive classes and cover
all the basic LabVIEW programming techniques. I really think that these two courses
are very important to take if you are going to be developing any type of
LabVIEW application.
As far as the Data Acquisition (DAQ) and Signal Conditioning courses, they
cover important DAQ concepts in general but they are geared towards our DAQ
boards and not really the FPGA board you have. The FPGA course teaches you more
about FPGA programming and not so much about DAQ. If you are going to be doing
DAQ with FPGA boards I think that taking both of these courses would be very
helpful.
If you have more questions you can call our Customer Education Department and
they can answer more specific questions. The number is (800) 531-5066. You can
also post more questions here and I will be glad to help you out as much as I
can.
04-02-2008 03:14 PM
04-02-2008
03:37 PM
- last edited on
04-25-2025
12:34 PM
by
Content Cleaner
Not trying to but in but have you considered the NI Training and Certification Membership program? I might be worth the cost if you are going to take alot of NI courses.
https://www.ni.com/en-us/shop/product/training-membership.html
04-03-2008 10:20 AM
