Timing in a DAQ loop with write, read, then a little processing
Looks good. As for adding counters, I beleive the 6052e has only the two counters, but you can certainly add more from other cards. Unfortunately, I don't know about triggerring digital outputs with counters using the 6052e, but based on the lack of supported examples, I'm doubtful, though I would certainly be interested in hearing the answer.
Message 11 of 13
(908 Views)
I can happily report that the vi I attached does work.
However, you are absolutely correct - the 6052E only has 2 CTR outs. Also, my investigations would suggest digital outputs cannot be triggered by counters at all on this card.
What I will do is use this setup for the current application, and when I require 4 bits for setting the switch state I will build a little 4-bit counter and just use CTR0 to clock it externally.
I would consider my original problem resolved - due entirely to your assistance.
Therefore, many many thanks for your help! I hope I will be able to help someone else in that fashion at some point.
Philip
Message 12 of 13
(904 Views)
Great. I'm glad it worked out for you. Good luck with the rest of your prog.
Message 13 of 13
(896 Views)
