To generate a sinusoidal waveform of given frequency from DAQ 6251
How can I generate a sinusoidal waveforms of given frequency from DAQ 6251? I have tried using waveform generation from signal processing toolbox, but it seems that it is writing only the first or the last sample, not all. I faced this condition when I tried to write through analog 1D double multichannel waveform.
(3,262 Views)
Accepted by theRooK
In the examples, look at Con Gen Voltage Wfm-Int Clk.
If you continue to have problems, post the code you have written.
(3,254 Views)
Thank You... Could you tell me where the waveform buffer came from? I mean which toolkit is it located in?
(3,236 Views)
The function is not part of any toolkit. It's part of _Utility.llb that is in the examples\DAQmx\_Utility folder.
Finding the location of this VI is simply a matter of doing a Save As and looking at the path in the dialog window.
(3,230 Views)
