Multifunction DAQ
To power up SCXI 1000 chasis module with Pseudo sinusoidal input mains
Is it imperative to power up SCXI 1000 chasis module with a Pseudo sinusoidal waveform input mains rather than pure sinusoidal waveform?
will it affect the the performance and reliability of the DAQ module to provide it input power with a  Pseudo sinusoidal waveform input mains?
Regards
Jamal
(4,313 Views)
Accepted by Mr_Engineer
Hi Jamal,
If you look at page A-2 of the 1000 user manual found here you can see that the power requirements for the 1000 are not too strict. So I imagine that if your mains are nearly sinusoidal at around those AC voltages then you won't have an issue.
Brian H. -- Electronics & Measurements Product Marketing Manager
(4,287 Views)
