Transferring two PCI cards from one desktop to another
FIrst off, apologies for my computer naivete.  I am using a system developed by someone else, and obviously know very little about this matter.
I am using a system to record data that consists of two NI BNC-2110 connected to two PCI-6133/1912151-03 cards that are connected together (with some type of wide white cable).  Each PCI card is connected to a different PCI slot in the desktop.  It is running programs in Labview 8.2.
I need to travel with my system, but cannot take my desktop computer.  I know that you should be able to transfer the PCI cards from one computer to another, but will I have problems since I am operating two simultaneouly?
Also, I am traveling internationally.  Are there any minimum specs I need to ensure are on the computer at my destination to properly run this system?
And finally, aside from the Labview software and drivers for the PCI cards, do I need to bring anything else to ensure this will properly operate on another computer?
Thank you!
(2,669 Views)
You only need drivers for those PCI cards & offcourse the software for the application you want to run using these cards.
else for computer configuration should be good
like atleast
RAM 256MB,
HDD 10GB in  installing drive usually C
Processor P-4
etc.
Thanks & Rgards
Love Diwan
There is always a better way to do things.................. "Just Find It"
(2,657 Views)
