pci-6225 crashing
Hello All,
I have a pci-6225 and I would like to rule out something that might be happening. Is there a chance that this device would cause an exception if, for instance, the board temperature goes above the maximum(55º C)?  I am asking this question because my application sometimes crashes when operating at the customer location while in my office it works fine. Besides, this crash happens after about 3 hours of operation and I believe that this might be something to do with the temperature there, since everything else is exactly the same. Another thing, what else woud cause the board to switch off by itself.
Fred
(3,074 Views)
I had search for this information and according with the following manual, the operating temperature for this board is between -20 and 70º C. Look at page 12 for see this information.
http://www.ni.com/pdf/manuals/371290g.pdf
If the temperature in the enviroment is about 55º, maybe that is not the problem.
What other informations could you give me for I can help you?
Regards.
Luciano Borges
National Instruments Brazil
Luciano Borges
Test Development Engineer
(3,024 Views)
Hello Fred
I think Temperature cann't be the problem in the PCI Cards. it can be your application which is crashing please check your appliction software.
also you focus over memory management, you can also check in Task manager for a particular application.
Regards
Love Diwan
There is always a better way to do things.................. "Just Find It"
(3,017 Views)
