Triggering NI9263 card (Voltage Output) with NI9215 (Voltage Input) on cDAQ-9174
Hello all,
I am able to generate the desired signal using Analog output module NI 9263 on cDAQ 9174. I have been triggering/starting the generation using from Labview. I would now like to trigger the same externally using analog input voltage of a certain threshold. I intend to use Ni-9215 (analog input) module for triggering the analog output.
I am wondering if that can be done. Any help will be highly appreciated.
Thank you.
Pieterson
Message 1 of 1
(1,986 Views)
