I am having some difficulty setting up a pressure transducer read with my NI hardware. I have an Omega PX-205 pressure transducer :
http://www.omega.com/manuals/manualpdf/M2165.pdf that I am trying to hook up to my SCB-68 box, and I am using Labview 7.1 with NI-DAQmx to read the signal and I have a PCI-6023E card in my computer.
My box reads all my other eqiupment fine, but I just aquired the pressure transducer and so far its not working out. I've wired the trasducer to the scb box and power supply as shown in the pdf and I'm seeing the following results:
When I turn on the power supply, my voltage read out goes immediatly to +10 volts, which is the "MAX Input Range" value in my MAX window. I tried increase the Max Input range, but anything up +10 volts gives me a "Error -200077 occurred at DAQ Assistant"
message which I am not sure how to fix. I have also tried to read a current from the box and it gives me a similar problem, resulting in + 40 mA signal which again is the Max Input range. After I unplug the power supply, the signal drops back down to zero. My power supply supplies 16 volts DC.
Any advice on what to try next would be very helpful,
-David
