Two continuous pulse trains on PCI 6723
Hello
I need to write .net code to generate two continuous pulse trains at the same time or with the 2nd pulse train at a fixed delay from the first on PCI 6723
I find the same question on http://forums.ni.com/t5/Multifunction-DAQ/Two-puls​e-trains-with-fixed-phase-delay-using-USB-6216/td.... The solution work successful on NI 6281, but I am fail on PCI 6723
I want to know does it possible create two continuous at the same time or with fixed delay using NI PCI 6723?
(2,862 Views)
Update: One Ni software engineer send me a link regarding this issue https://decibel.ni.com/content/docs/DOC-10321. But i think PCI 6723 can not support arm start trigger.
(2,838 Views)
