Two same board on a computer
I would like to know if there are problems to work with two PCI-6321 on a computer. Boards will working in same time but acquisitons will be different.
If there are problems, what do you recommend?
Thanks very much.
Romain
(4,277 Views)
I'm guessing you mean PCIe-6321, but there should be no problem using 2 cards simultaneously.
Depending on your sampling and timing requirements, make sure you look into the steps to synchronize these measurements.
- P
(4,268 Views)
