Multifunction DAQ
USB-6000 background apps
Why does it take 16 background processes to run my USB DAQ?  I didn't even load all the $h!+ from the CD.
Message 1 of 8
(5,016 Views)
What processes do you mean?
Is the device working properly?
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 2 of 8
(5,013 Views)
I see in my System Config (msconfig) the following NI tasks:
NI PSP Servoce Locator
NI Time Synchronixation
NI PXI Resouce Manager
NI Service Locator
NI Device Loader
NI Cinfiguration Manager
NI Application Web Server
NI Domain Service
NI License Server
NI mDNS Responder Service
NI LXI Discovery Service
NI Network Discovery
NI System Web Server
NI Variable Engine
nidevmon
NIUpdateService
NI Error Reporting
What I find troubling is I don't have LXI, PXI,LabVIEW and don't plan on using the DAQ over the web or network. The updater wanted to get updates for LabVIEW that is not even on my machine!  The instrument will be in a standalone machine measuring voltage controlled with a ,Net C# program.  Which of these services are absolutely necessary?
David Hodgkins
Message 3 of 8
(4,984 Views)
List of Windows Services Installed By National Instruments Software
http://www.ni.com/white-paper/14487/en/
You can decide for yourself which services you'd like to stop based on their functionality.
Nathan Murphy
C Series I/O Product Manager
Message 4 of 8
(4,960 Views)
The only thing you should need is the NI-DAQmx driver: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du/q/daqmx/
Message 5 of 8
(4,952 Views)
OK, That's sound better, I'll give it a try,
David
Message 6 of 8
(4,942 Views)
Hi Craig,
I got a chance to go to the link you provided but found many choices.  I am supporting XP & windows 7 Test stations runing C# windows test programs.  Should I install NI-DA!mx Base 3.7.
David
Message 7 of 8
(4,905 Views)
Hey David,
I would recommend the latest current version of DAQmx.
As of October 2013 this is DAQmx 9.8: http://joule.ni.com/nidu/cds/view/p/id/4297/lang/en
Message 8 of 8
(4,895 Views)
