USB-6001 - National Instruments on Mas OS 10.15.4
Hi
I'm trying to install the NI-DAQmx Base on my mac os 10.15.4. I get the following error:
This package is incompatible with this version of macOS.
The package is trying to install content to the system volume. Contact the software manufacturer for assistance.
Is there any workaround for that? Or different driver that I could use?
Thank You
(2,002 Views)
Hello pdesolver,
Based on this article that behavior was expected. The driver is not supported for Mas OS 10.15.4 version.
Buy the way DAQmx Base Driver was end of life unfortunately.
__________________________________________
The best way to thank, is to give KUDOS
(1,928 Views)
