 nyc_(is_out_of_
			nyc_(is_out_of_07-22-2014 09:48 AM
I working on a project with LabVIEW 6.1.
They have just purchased a NI USB-6001.
I installed NI-DAQmx 9.9, and the device shows up in NI-MAX and I am able to use the Test Panels to read and set pins.
In LabVIEW 6.1, the device does not show up.
What do I do to be able to program this device with LabVIEW 6.1?
Solved! Go to Solution.
 Dennis_Knutson
			Dennis_Knutson
			07-22-2014 10:24 AM
 crossrulz
			crossrulz
			07-22-2014 10:57 AM
DAQmx 9.9 only supports back to LabVIEW 2010.
NI-DAQ and LabVIEW Version Compatibility (for Windows)
 nyc_(is_out_of_
			nyc_(is_out_of_07-22-2014 11:15 AM
Thanks all.
It is as I had feared.
I found a laptop with LabVIEW 2013, and the device is detected.
I want to set PO.0 and read PO.1 and read AI.0 and AI.4 and write to AO.0
Do I need to set up tasks and channels?
I can't seem to figure out how to use the DAQmx Device Name handle and be able to simply control the pins.
 crossrulz
			crossrulz
			07-22-2014 11:21 AM
You need tasks in order to use teh DAQmx Read and DAQmx Write. You can create the tasks in MAX or do it programatically with the available VIs in the DAQmx palette.
