USB-6003 compatible software for collecting and recording voltage signal and displaying data
What I need: NI or comparable software to work with a the analog input of the USB-6003 to collect and record voltage from my instruments and display data.
Is NI Signal Express 2015 the right software? I have the project set up in Signal Express and DAQExpress. It seems as though DAQExpress only allows collection from one channel at a time and will only display voltage. I was hoping to have a software that would let me say, for example, 2 volts = 0 psi and 10 volts = 150 psi, and display a graph of the pressure instead of the voltage being measured.
Message 1 of 1
(1,086 Views)
