USB-6008 Current Limitation
I am using the USB-6008 device in a new application to first read the analog values and then fire solenoids based on the readings.  The current limitation on the USB-6008 is 8.5 ma as per the specs and the device I want to drive is rated 5v at 38 ma.  Does anyone know of an application to increase the output of the USB-6008, such as with a transistor or analog switch?
RDD
(3,917 Views)
Accepted by RDD
You can use one of the ULN2xxx relay drivers.
(3,914 Views)
Thanks Dennis,
This should work nicely.
RDD
(3,907 Views)
I didnt know that... thanks for posting it out
Best Regards
(3,879 Views)
