USB-6008 Current Limitation
I am using the USB-6008 device in a new application to first read the analog values and then fire solenoids based on the readings.  The current limitation on the USB-6008 is 8.5 ma as per the specs and the device I want to drive is rated 5v at 38 ma.  Does anyone know of an application to increase the output of the USB-6008, such as with a transistor or analog switch?
RDD
(3,948 Views)
Accepted by topic author RDD
You can use one of the ULN2xxx relay drivers.
(3,945 Views)
Thanks Dennis,
This should work nicely.
RDD
(3,938 Views)
I didnt know that... thanks for posting it out
Best Regards
(3,910 Views)
