08-31-2010 02:03 PM
I believe the driver files for the USB-6008 are about half a gig in size. Can I select a subset of them for my simple needs and if so how?
08-31-2010 02:16 PM
Only if you are doing a deployment. To do application development, you want the full driver which includes documentation and MAX. When you run the installer, you can choose to include application development support for whatever language you are using.
