 Nad
			Nad
			08-31-2010 09:39 AM
What is the protocol at serial input to NI-USB-9162 carrier? RS232?
 Seth_B.
			Seth_B.
			08-31-2010 09:58 AM
The D Sub connector uses SPI communication with a proprietary format. Is there something that you need the USB carrier to do that it doesn't do currently?
08-31-2010 10:00 AM
At which side? And what are you trying to do with it?
The computer interface is USB.
The C Series module interface is proprietary-- it isn't RS232. (Also, that's a DE-15 connector, not a DE-9.)
If you're trying to develop a module, you may want to look into the C Series Module Development Kit, but they'll only work in a CompactRIO chassis. The architecture for the USB-9162 is such that the device has to know how to interface directly with each module, which is why it supports a limited number of modules (all of which are NI-only).
08-31-2010 10:44 AM
I was thinking we might have an option to bypass the carrier, going to an RS232 on a USB Hub. I now know that is not an option. Thanks, Dan
08-31-2010 10:45 AM
Issue resolved.
