Multifunction DAQ
serial protocol, NI-USB-9162, carrier
What is the protocol at serial input to NI-USB-9162 carrier?  RS232?
(3,873 Views)
The D Sub connector uses SPI communication with a proprietary format.  Is there something that you need the USB carrier to do that it doesn't do currently?
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,864 Views)
At which side? And what are you trying to do with it?
The computer interface is USB.
The C Series module interface is proprietary-- it isn't RS232. (Also, that's a DE-15 connector, not a DE-9.)
If you're trying to develop a module, you may want to look into the C Series Module Development Kit, but they'll only work in a CompactRIO chassis. The architecture for the USB-9162 is such that the device has to know how to interface directly with each module, which is why it supports a limited number of modules (all of which are NI-only).
(3,863 Views)
I was thinking we might have an option to bypass the carrier, going to an RS232 on a USB Hub.  I now know that is not an option.  Thanks, Dan
(3,851 Views)
Issue resolved.
(3,850 Views)
