04-13-2011 11:01 AM
Dear NI Experts,
I'm try to control my USB-6008 by Excel (VBA). I already found an Excel example how to write to the digital output.
Does anyone could provide a most simple Excel-VBA code example how to read the analog input / write the analog output? Answers are very appreciated, many thanks in advance for help. Dirk
04-14-2011 01:04 PM
Hi DirkI,
I have some links with examples for you:
http://zone.ni.com/devzone/cda/epd/p/id/2470
http://zone.ni.com/devzone/cda/epd/p/id/305
I hope this examples are useful for you.
Best Regards Lam.
04-14-2011 11:46 PM
Hi Lam,
thank you for your help.
Unfortunately this stuff didn't moved me forward: The first excel-spreadsheet works -I assume- not with my USB-6008. A submacro "DAQ" is neccessary which probably my 6008 does not assist.
The second file is the identical file I already work with - unfortunately "only" writing the I/O-port.
Anyhow - many thanks - I will investigate further.
Best Regards Dirk
