USB-6008 used to time short circuit period
I inherited a USB-6008 and have never used it.  I'm trying to measure the period over which a circuit is closed.  Can the USB-6008 be used for this?  I don't need extreme accuracy (within 0.1 sec is sufficient).  I'm fine using the internal PC clock.
The input signal is simply a relay that is opens and closes.  I want to measure when the relay is closed. I don't currently have an installed version of LabView, so being able to do this manually with NI-DAQmx would be best.  Is that possible?
Any ideas?  I'm fairly new at this so simple explanations are much appreciated.
(2,822 Views)
USB-6008 doesn't have internal clock for Digital Input so, you can use internal PC clock only.
If the application isn't complex, I believe you can run your application within 0.1sec.
But there is a possibility of delay once the load of CPU increases.
By the way, DIO on USB-6008 is open collector. Is it OK?
Certified LabVIEW Developer
GCentral
(2,797 Views)
Thanks, Emboar.  To answer your question about DIO being open collector, I don't even know what that means, so I have no idea.
Do you have any suggestions on how I would hook up the USB-6008?  As I said, I'm pretty new at this, so if you can point me to a tutorial or something, that would be helpful.
Thanks in advance.
(2,774 Views)
Read this user manual.
On page 16, you can see how to connect a switch to USB-6008.
http://home.hit.no/~finnh/videos/topics/labview_analog_io/371303.pdf
Is this helpful for you?
GCentral
(2,764 Views)
