USB 6008
Can I use USB 6008 both in input mode and output mode simultaneously?
(3,472 Views)
Hi Sheejapgmanoj,
Yes, you can use the analog input at the same time you use the analog output channels.  They are controlled by two different tasks.   If you are looking for some getting started help with our DAQmx driver (which the 6008 uses), I would recommend taking a look at the site here.  Half-way down the page you can find some demos for  getting started with the DAQmx driver.
I hope this helps,
Paul C.
(3,455 Views)
Thanks for the reply. I am using it in the digital input and output mode.
Sheeja
(3,443 Views)
Hi Sheeja,
In that case, I'm assuming your asking whether the card supports the abiltity to tristate a line.  Unfortunately, the 6008 doesn't support tristating or the ability to use a digital line in both output and input mode.
I hope this helps,
Paul C
(3,438 Views)
