where's nivisa 4.4.0?
hi im trying to install nidaqmx base 3.2.0, in mandriva 2008 but i receive the following error:
NI-VISA 4.4.0 could not be installed.
Please run the NI-VISA installer in the nivisa subdirectory
and then re-run this installer.
NI-VISA 4.4.0 (or later) is required for
NI-DAQmx Base 3.2.0-f1
well i try to found NI-VISA 4.4.0 but only the nivisa 4.3.0 was avaible, how is that possible?
(2,919 Views)
Hello.
What does happen if you install NI-VISA  4.3.0? Have you always your issue?
Regards.
Romain D.
National Instruments France
(2,901 Views)
hi problem solved i run first ni-visa 4.3.0 and then when running nidaqmsx 3.2.0 the new driver replace ni-visa 4.3.0 for nivi-sa 4.4.0 automatically, tanks for help
(2,897 Views)
