USB 6009 OEM - ground problem?
I got some problems using these boards.
I connected them through the 34 pin connector to a pcb board, so there's no direct usb cable inserted in the NI board, but the usb cable is connected to the PCB.
I use a laptop to acquire signals, this laptop power supply has no ground. If I use this laptop on batteries everything is fine, if i use it with the power supply connected the usb 6009 stops working very often (the led goes off or stay steadly lit). The strange is that if I connect the power line ground to the pcb everything is fine as well.
I tried to connect the NI board directly with a standard usb cable and everything is ok also with power supply.
I think I have some problems with ground and/or shielding.
Anyone can help?
Thank you very much!
(3,360 Views)
Have a look at this:
My Laptop is Reading a Floating Voltage from a Grounded Source in Differential Mode
Also, be sure to have a look at Table 1 in the following article:
Field Wiring and Noise Considerations for Analog Signals
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,357 Views)
