output pulse train and use it as clock source for two DO
Hi ppl.
I am using a USB-6289 (two onboard counters ) and I am trying to create a "continuous" pulse train (no finite sample) using
counter 0, and then use this signal as a timming source to two digital outputs of different data (I need them to be
in sync with the pulse train)...
However I can get the pulse and the first DO in sync, but when I try to introduce the pulse train as a timming source
to the second DO, I get an error report from LabVIEW saying something like "the resource is already in use" or something
like that.
Does anyone has experienced something similar...sure could use some pointers...
I didn't upload the code because I am just trying to find if what I am trying to do is feasible....
Hope to have some inputs Smiley Wink
Cheers.
(3,036 Views)
Hi Rsilva,
You cannot create two DO task running in parallel. Use a single task with multiple channels in it if you want to generate on multiple DO.
Alexandre M. | Certified LabVIEW Developer
Embedded and Control Systems Engineer (NI France)
(3,008 Views)
