USB-6009 not installing drivers under WinXP
Hello. I am attempting to install a USB-6009 on a WinXP installation on a Mac. I am running LabVIEW 2009 Student Edition, and have installed DAQmx 9.2.1. When connected, XP detects the USB-6009, but when it tries to install the drivers, it says it cannot find them. I have reinstalled DAQmx and LabVIEW to see if I had a broken installation. I have tried this under both VMWare Fusion, and directly booting into WinXP via bootcamp, but no success. Any ideas? Thank you.
(2,994 Views)
Do you have any files in Program Files\National Instruments\NI-DAQ\staging\niem ??
Can you tell Windows to use the inf file located in that directory?  What happens?
-gaving
(2,969 Views)
