USB 6009 sample rate for N channels
The USB 6009 max sample rate is 48k S/S. My question is, does this scale down proportionally for N channels, where N is not a power of 2?
Specifically, if I set up six (6) channels for acquisition, while my sample rate be 48k/6 = 8k S/S? Or will it need to be reduced to 48k/8?
Mark
(3,290 Views)
If you set the DAQmx task to read 6 channels, it will read only those 6 at whatever rate you set, up to the max aggregate rate.  So yes, 8kS/s.
--Using LV8.2, 8.6, 2009, 2012--
(3,277 Views)
Thank you - this is what I suspected, but wanted to double check.
Mark
(3,275 Views)
