Multifunction DAQ
USB 6009
Hi everyone..
I'm a student and I started using labview. Please, could someone help me with a problem?
I'm running tests waveforms charge and discharge of a capacitor, and I want to stay on, collecting data for one week, no interruption.
The block diagram doesn´t measures two inputs at the same time. What am I doing wrong in the block diagram?
(5,659 Views)
Accepted by Saille
You don't have an error out indicator do you don't see the resource reserved error. You must use s single task with multiple channels. Use Dev1\ai0:1 to acquire from both channels. This is a very common mistake.
(5,652 Views)
Thank very much, Dennis.
But, I have one more question, please.
I'm measuring two capacitors, I would like to put each signal in a chart....is this possible?
And sorry because my english is not very good.
Saile
(5,630 Views)
It's simple. You're getting a 1D waveform array. Index the array.
(5,626 Views)
Perfect!! The circuit worked..
Thank very muck!!! Dannis
(5,617 Views)
