USB 6009
Hi everyone..
I'm a student and I started using labview. Please, could someone help me with a problem?
I'm running tests waveforms charge and discharge of a capacitor, and I want to stay on, collecting data for one week, no interruption.
The block diagram doesn´t measures two inputs at the same time. What am I doing wrong in the block diagram?
(5,605 Views)
Accepted by topic author Saille
You don't have an error out indicator do you don't see the resource reserved error. You must use s single task with multiple channels. Use Dev1\ai0:1 to acquire from both channels. This is a very common mistake.
(5,598 Views)
Thank very much, Dennis.
But, I have one more question, please.
I'm measuring two capacitors, I would like to put each signal in a chart....is this possible?
And sorry because my english is not very good.
Saile
(5,576 Views)
It's simple. You're getting a 1D waveform array. Index the array.
(5,572 Views)
Perfect!! The circuit worked..
Thank very muck!!! Dannis
(5,563 Views)
