USB 6211 Driver Poblem
Hi all,
I have a problem with USB 6211.
I have Window XP and installed Labview 8.5.
Which is the best version for USB 6211 drivers I should install?
I tried version 9.0 (the older that I can download from website) and it's not working.
Does anyone of you have older versions to share with me?
Thank you
(1,699 Views)
You need DAQmx between 8.6.1 and 9.3 for LabVIEW 8.5
Refer to the compatibility table at https://www.ni.com/content/ni/langs/en/support/documentation/compatibility/16/ni-daqmx-and-labview-c...
Can you elaborate "I tried version 9.0 (the older that I can download from website) and it's not working."?
Santhosh
Soliton Technologies
(1,666 Views)
