USB-6221, serial number N/A
I've installed the same USB-6221 device on two computers together with DAQmx 8.8 drivers. Serial number of the device cannot be seen on one of them. MAX shows "N/A".
Configuration:
Computer 1: Windows XP SP 3, DAQmx 8.8, Developer Suite 8.6, serial number is O.K.
Computer 2: Windows XP SP 2, DAQmx 8.8, LV RunTime Engine 8.6, serial number N/A
 The same data aqcusition application works on both of them.
I would need some help to clarify what's going wrong.
Thanks in advance,
Ljubo
(3,080 Views)
Hi Ljubo,
Thanks for the post and I hope your well today.
Have you tried using LabVIEW to get the serial number?
Under DAQmx if you go to DAQmx Device Property Node then Identification and Device Serial Number. Does it work on the second machine?
As for why MAX works for one and not the other - Im not sure.. if the code works what is the issue?
Have you got the same version of MAX installed?
THanks,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,059 Views)
Hi James,
In fact, I'm not well today. I've got flu and I'm warmed up to 38,5 degrees. I will chech everything once again when I'm back in my office.
Ljubo.
(3,041 Views)
