12-11-2012 01:45 PM - edited 12-11-2012 01:48 PM
HI,
I'm having an issue creating two analog interfaces. I keep receiving an error when I try to address a range "Dev1/ao0:1". I can address "Dev1/ao0" and create an nice sinusoid. The issue is I want to utilize both an0 and an1 analog interfaces to output signals. I'm developing in C++. Any ideas why I can not address both analog outputs? I have tried to use ao1 and the port works just fine.
Code:
#include <QtGui/QApplication>
#include "mainwindow.h"
#include "ni_usb_6361.h"
#include "math.h"
#include <QDebug>
#define DAQmxErrChk(functionCall) { if( DAQmxFailed(error=(functionCall)) ) { goto Error; } }
#define PI 3.1415926535
int main(int argc, char *argv[])
QApplication a(argc, argv);
MainWindow w;
w.show();
int error=0;
TaskHandle taskHandle=0, taskHandle2=0;
float64 data[4000], data2[36000];
char errBuff[2048]={'\0'};
int i=0;
int32 written;
int32 read;
for(i=0;i<4000;i++)
data[i] = 1*sin(2*PI*100*i/1000);
/*/ DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0:1","",-5.0,5.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,4000));
DAQmxErrChk (DAQmxCreateTask("",&taskHandle2));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle2,"Dev1/ai0","",DAQmx_Val_Diff,-5.0,5.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle2,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,4000));
/*/ DAQmx Write Code
DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,4000,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL));
/*/ DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
DAQmxErrChk (DAQmxStartTask(taskHandle2));
/*/ DAQmx Wait Code
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle2,4000,10.0,DAQmx_Val_GroupByChannel,data2,36000,&read,NULL));
DAQmxErrChk (DAQmxWaitUntilTaskDone(taskHandle,10.0));
qDebug("Acquired %d points\n",read);
qDebug()<<data2[0];
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
/*/ DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
if( taskHandle2!=0 ) {
/*/ DAQmx Stop Code
DAQmxStopTask(taskHandle2);
DAQmxClearTask(taskHandle2);
qDebug("DAQmx Error: %s\n",errBuff);
qDebug("End of program, press Enter key to quit\n");
return a.exec();
Thank you
12-12-2012 09:13 AM
Hi DSTEG,
Can you post the error that you're getting?
Carmen C.
Application Engineer
12-12-2012 11:57 AM
I figured out the issue. The issue was with:
DAQmxWriteAnalogF64(Analog0,4000,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL);
It was unclear that the output write is per channel. If we are using two channels then the output write samples must be half of the total buffer. I had to change the write to:
DAQmxWriteAnalogF64(Analog0,2000,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL);
and then it worked.
Thank you.
