USB-6251 , DAQmx Analog Output, ao0, ao1, error utilizing both ports
HI,
I'm having an issue creating two analog interfaces. I keep receiving an error when I try to address a range "Dev1/ao0:1". I can address "Dev1/ao0" and create an nice sinusoid. The issue is I want to utilize both an0 and an1 analog interfaces to output signals. I'm developing in C++. Any ideas why I can not address both analog outputs? I have tried to use ao1 and the port works just fine.
Code:
#include <QtGui/QApplication>
#include "mainwindow.h"
#include "ni_usb_6361.h"
#include "math.h"
#include <QDebug>
#define DAQmxErrChk(functionCall) { if( DAQmxFailed(error=(functionCall)) ) { goto Error; } }
#define PI	3.1415926535
int main(int argc, char *argv[])
    QApplication a(argc, argv);
    MainWindow w;
    w.show();
        int         error=0;
        TaskHandle  taskHandle=0, taskHandle2=0;
        float64     data[4000], data2[36000];
        char        errBuff[2048]={'\0'};
        int			i=0;
        int32   	written;
        int32       read;
        for(i=0;i<4000;i++)
            data[i] = 1*sin(2*PI*100*i/1000);
        /*/ DAQmx Configure Code
        DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
        DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0:1","",-5.0,5.0,DAQmx_Val_Volts,NULL));
        DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,4000));
        DAQmxErrChk (DAQmxCreateTask("",&taskHandle2));
        DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle2,"Dev1/ai0","",DAQmx_Val_Diff,-5.0,5.0,DAQmx_Val_Volts,NULL));
        DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle2,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,4000));
        /*/ DAQmx Write Code
        DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,4000,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL));
        /*/ DAQmx Start Code
        DAQmxErrChk (DAQmxStartTask(taskHandle));
        DAQmxErrChk (DAQmxStartTask(taskHandle2));
        /*/ DAQmx Wait Code
        DAQmxErrChk (DAQmxReadAnalogF64(taskHandle2,4000,10.0,DAQmx_Val_GroupByChannel,data2,36000,&read,NULL));
        DAQmxErrChk (DAQmxWaitUntilTaskDone(taskHandle,10.0));
        qDebug("Acquired %d points\n",read);
        qDebug()<<data2[0];
    Error:
        if( DAQmxFailed(error) )
            DAQmxGetExtendedErrorInfo(errBuff,2048);
        if( taskHandle!=0 ) {
            /*/ DAQmx Stop Code
            DAQmxStopTask(taskHandle);
            DAQmxClearTask(taskHandle);
        if( taskHandle2!=0 ) {
            /*/ DAQmx Stop Code
            DAQmxStopTask(taskHandle2);
            DAQmxClearTask(taskHandle2);
            qDebug("DAQmx Error: %s\n",errBuff);
        qDebug("End of program, press Enter key to quit\n");
    return a.exec();
Thank you
(3,230 Views)
Hi DSTEG,
Can you post the error that you're getting?
Carmen C.
Application Engineer
(3,198 Views)
I figured out the issue. The issue was with:
DAQmxWriteAnalogF64(Analog0,4000,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL);
It was unclear that the output write is per channel. If we are using two channels then the output write samples must be half of the total buffer.  I had to change the write to:
DAQmxWriteAnalogF64(Analog0,2000,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL);
and then it worked.
Thank you.
(3,193 Views)
