USB-6501 interface question
When an I/O on the NI USB-6501 is configured as an input, is the 4.7k pull-up to the internal 5V present on the I/O or is the pull-up only there if configured as an open-drain output?
(3,318 Views)
Accepted by topic author Larry Strickland
That pull-up is in hardware... doesn't change when you reconfigure the port.  It's just inside the output terminals.
(3,314 Views)
