USB DAQ 6363 measurement bad with several channels
Hi All,
We are using NI DAQ USB 6363 for current measurement in differential mode.
1/
When using one channel, measurement can be done up to 2Msamples/s.
But when using 2 to 16 channels, average measurements are wrong when sampling is over 10ksamples / s / channel !
FYI, Current signal is around 1 to 10 mA with 0.1ohm resistor, so signal measurement is noisy
I suppose it's due to input multiplexer before PGIA who can't sample higher ?
What is specification limits for this product?
2/
I want to use pythom script to run current measurement in remote
Which Python library do you advice to control USB-6363 DAQ? ( i found ctype on google)
Laurent
Message 1 of 21
(4,877 Views)
Hi Laurent,
How many channels are you using for your application ? Only 2 or more ?
Moreover for your Python script, you can use the ctypes FFI package to control your DAQ board. The link below will help you to understand the package through tutorials,... :
How Can I Call DAQmx C Functions in Python?
Message 2 of 21
(4,842 Views)
Hi Antonin,
Thanks for your answer.
For measurement, following testcase we run, we can use up to 16 channels.
But sampling problem appears when we activate at least 2 channels
I use LabView signal express to do current measurement
If needs, i can send snapshot
Laurent
Message 3 of 21
(4,837 Views)
Yes please, it could maybe help me to go further.
Message 4 of 21
(4,832 Views)
Hi Antonin,
I made some screenshot showing problem I explained:
I use a waveform generator to output sinusoidal signal at 1hz with ~5mV offset.
1/
When I configure SignalExpress with sample to read=20k, Rate=1M, 1 channel
average is 5,12mA
2/
When I configure SignalExpress with sample to read=20k, Rate=1M, 2 channels
average is 5,62mA
=>So 0.5mA higher when I add a second channel
=> Not Good
3/
When I configure SignalExpress with sample to read=2k, Rate=100k, 2 channels
average is 5,12mA
=>By decreasing rate from 1M to 100k with 2 channels, I have same result that case 1/
So it seems that with more than one channel, we can't use max sample rate possible ?
I will send snapshot by mail
Laurent
Message 5 of 21
(4,818 Views)
Hi Laurent,
I encourage you to attach the files on your post, it will be easier for you and us 😉
Message 6 of 21
(4,815 Views)
Antonin,
With snapshot
I saved also seproj config files but I can't attach them in this thread, I can send to your mail if needed
1/
average is 5,12855mA
2/
When I configure SignalExpress with sample to read=20k, Rate=1M, 2 channels (second channel not displayed,but configured)
average is 5,62893mA
=> Not Good
3/
When I configure SignalExpress with sample to read=2k, Rate=100k, 2 channels (second channel not displayed,but configured)
average is 5,12211mA
Message 7 of 21
(4,808 Views)
Hi Laurent,
Do you observe the same behaviour with MAX when you look into the tests panels for analog input ?
Message 8 of 21
(4,783 Views)
Hi Antonin,
I use averaging function on SignalExpress, i think it's not possible with MAX tool?
Laurent
Message 9 of 21
(4,779 Views)
Oups you're right, I meant with LabVIEW (or another programming language) ? Or are you only using SignalExpress for your project ?
Message 10 of 21
(4,775 Views)
