USB-TC01 gives error -201165 "firmware for this device is too new"
m.caron,
Thank you for your feedback, we really appreciate it! We will take this into consideration.  I'm glad you were able to still find the resources to solve your issue as well 😃
Have a good day!
Aaron L.
Message 11 of 40
(4,461 Views)
I'm getting this same error message with the USB-TC01. I'm using LabVIEW 2010 with DAQmx 9.9 and I just followed the instruction to update the TC01 firmware to version 1.2. Do I need to downgrade the firmware or upgrade LabVIEW?
Gary
Message 12 of 40
(4,328 Views)
Update DAQmx to the latest and get the tc01 update tool!
Message 13 of 40
(4,299 Views)
LabVIEW 2010 doesn't support the latest DAQmx version, unless I'm mistaken.
Message 14 of 40
(4,283 Views)
You are correct LabVIEW 2010 only supports up to DAQmx 9.9 (http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248).  Do you have a newer version of LabVIEW to try?
Aaron L.
Message 15 of 40
(4,277 Views)
I do not, but I could see about getting a newer version. Is this the only solution?
Message 16 of 40
(4,260 Views)
It would be worthwhile to troubleshoot it on a newer version, but before you do that I would try doing a reinstall of your drivers and the firmware.
Aaron L.
Message 17 of 40
(4,222 Views)
If the hardware revision of the USB-TC01 is D (PN: 195564D-01L) or later, it is supported by DAQmx versions 14.5 or later, only.  If the device is a revision C or earlier, you should be able to downgrade the firmware for compatibility with earlier versions of the driver.
Message 18 of 40
(4,214 Views)
I am getting the same error.  I just purchased a USB-TC01 and the firmware updater is showing that the current firmware on the device is the same as what the software wants to put on which is 1.1.0f1  I am running Labview 14.0f1 with Max 14.0.0f0.
Any suggestions would be appreciated.
Message 19 of 40
(4,101 Views)
Try this update utility http://www.ni.com/download/ni-instantdaq-firmware-update-utility-1.2/5284/en/
Aaron L.
Message 20 of 40
(4,085 Views)
