Multifunction DAQ
USB daq adn FPGA not recognised
Hi
I have a USB-6211 DAQ. However I am not able to access it. I try following this KB article . "http://digital.ni.com/public.nsf/allkb/1448A8AC665EE0EA8625703F004A4410?OpenDocumenthttp://digital.n...
But I get an error after step 6 saying "Access is denied".  I am also having issues reaching my FPGA compiler Is there as solution?
(4,208 Views)
What version of DAQmx do you have installed?  Why are you trying to switch to DAQmx Base?  What does an FPGA compiler have to do with an M series DAQ device?
(4,207 Views)
Hi
I am using NI-DAQmx 9.9. I was using NI-DAQmxbase as I was experimenting with using NI_DAQ in C++. The FPGA error has happened at the same time so I am presuming they are linked?
(4,203 Views)
