‎09-15-2006 01:03 PM
‎09-18-2006 10:18 AM - edited ‎09-18-2006 10:18 AM
Hi E Murphy!
Are you doing a finite or continous adquisition? Does this problem also occurs when you are not using a trigger? Have you tried to modify the samples per cycle to see if that has any effect?
What version of the driver are you using? Are you using LabVIEW (what version?)? Or using another software?
If you give me a little more of details, we can try with an example and reproduce the problem.
We also need to know if we are using the minimum system requeriments for the hardware and software, so we need to know what processor, RAM, OS, we are using in each laptop.
Also, are you using High speed USB ?
Tania Lozoya
NI MEXICO
Mensaje editado por Tania Lozoya
‎09-18-2006 12:23 PM
‎09-18-2006 01:09 PM
Hi E Murphy,
Well if you are doing finite adquisitions, the pauses could happening between one fine adquisition and the next. Can we make a test a do an continuos adquisition, to see if the pause occurs during a continiuous adquisition. If this is the case, the problem could be in the board, if not, we can try something in software, maybe changing the samples to read in the finite adquisition, maybe we are using a large number of samples in every iteration. Can you tell me some of the samples to read, and the sample rate, is this in just one channel?
Tania Lozoya
NI MEXICO
‎09-19-2006 11:23 AM
‎09-22-2006 03:32 PM
‎09-25-2006 12:23 PM
Hello Tania:
I have tried on demand acquisition of samples and only get some trouble when trying to read more than 8000 samples at more than 50 kHz (2 channels) I have "solved" this lowering the number of samples.
With the triggered acquisition I first detrmine the speed (measure period) and then establish the sampling frequency. If I continuously read the speed, I have no problem. It is when speed and acquiring samples cycles that give the pauses.
Regards
Eduardo Murphy
‎09-25-2006 01:56 PM
Hi!
Have you tried with one of the shipping examples?, so we have code in common, this model uses USB 1.1, it could be the USB connection, but to make sure, I would like to use the shipping examples, to see if you have the same behavior.
Tania Lozoya
NI MEXICO
