USB device can perform faster
The USB-6008 appears under the Standard Open HCD USB Host Controller, and not under the Enhanced PCI to USB Host Controller.  It doesn't say "USB2" anywhere that I can see.
Edward Motts
Certified LabVIEW Associate Developer
Message 11 of 23
(3,846 Views)
As Seth suggested, have you tried another USB 2.0 device? Does it show up under the Enhanced host controller?
Matt
Message 12 of 23
(3,822 Views)
Shot in the dark..
Any chance your BIOS is an EFI bios?..  I have the exact same problem on 12 iMacs running NiDAQmx 9.1 and I suspect it is because there is a problem with the driver and the EFI bios the Macs use. (I'm running BootCamp, which should allow the iMacs to run Win7 natively, but I guess there could be something there)..
Dave Crabbe
 Nova Scotia Community College
Message 13 of 23
(3,817 Views)
Matt W, the only other USB 2.0 device I had on hand is a memory stick, and it does not complain about "This device can perform faster."  But I have not looked at the Device Manager to see how it connected.  I will look at that.
Dave Crabbe, I don't think it's an EFI BIOS, I think it's an Award BIOS.  But I'm still at work and can't look at it right this minute--tonight I will check.
Ed
Edward Motts
Message 14 of 23
(3,813 Views)
Tonight I had a chance to plug a USB 2.0 thumb drive into a port.  It does not report "This device can perform faster," and it does appear in the Device Manager under the Enhanced Host Controller.  And as you can see below, the USB-6008 does not.
Edward Motts
Message 15 of 23
(3,802 Views)
Dave Crabbe,
Mine is a Phoenix AwardBIOS.  Sorry, no EFI.
Ed
Edward Motts
Message 16 of 23
(3,799 Views)
What version of DAQmx is installed on each computer? Are they very different versions? Also, bigger pictures would be better in the future, those two are kind of hard to make out.
Matt
Message 17 of 23
(3,780 Views)
Matt W.,
My home computer, where the "Device can perform faster," has DAQmx 8.9.5f6.  My work computer, where it seems to work as expected, has DAQmx 8.9.5f5.
Ed
Edward Motts
Message 18 of 23
(3,772 Views)
Accepted by topic author EMotts
Hi Edward,
Since the 6008 is a bus-powered device, one possible cause of this behavior would be if the PC cannot provide enough power over USB to support the full bandwidth of USB 2.0 (a USB DAQ device is going to draw much more current than an external flash drive).
Assuming you have tried multiple USB ports already, I would suggest to try using an externally-powered USB Hub which should hopefully fix the issue if this is indeed the problem.
Best Regards,
John Passiak
Message 19 of 23
(3,750 Views)
We have a solution.  As John P suggested, I connected the USB-6008 through an externally powered USB Hub, and the problem went away.
Many thanks to all who replied with suggestions.
Ed
Edward Motts
Message 20 of 23
(3,735 Views)
