Multifunction DAQ
USB <--> PCIe
How does the speed of USB DAQ devices compare to the speed of PCIe cards (analog and digital)?
By that I mean if a USB DAQ can take X measurements per second  and a PCIe card can take Y measurements per second,
how do X and Y compare to each other?
(4,712 Views)
Accepted by WayneS1324
If it is the same model number, they are equal.  I highly recommend going with PCI(e) anyways since I seem to have nothing but problems with USB (it got unplugged, Windows decided to remove USB bus power, etc etc et).
(4,706 Views)
Thanks for the reply.
I want to move from C# and/or LabWindows and give a project a go with C++. USB devices are eaiser to interface with.
(4,704 Views)
Not really.  DAQmx takes care of it all for you.  So there is not really any difference other than the initialization (where you define which channels to be in a task).
(4,698 Views)
