Multifunction DAQ
USB to PCMCIA adapter for 6020E? Is it possible? Recommendations
Is it possible to use an adapter USB to PCMCIA in order to use a PCMCIA 6020E on a newer (no PCMCIA slot) laptop?
If so what do you recommend?  Will Labview recognize the device?
(4,295 Views)
Hey Rbmtx,
Thank you for contacting National Instruments. Unfortunately, NI does not sell a USB to PCMCIA card adaptor. Also we have not tested our PCMCIA cards with third party adaptors. There may be an adaptor on the market that will work, but in a preliminary search I didn't see many options out there that I think would work. I doubt there is a real viable solution available due to the differences in the way we handle data acquisition and generation on PCMCIA versus the USB bus. If you are interested in a USB data acquisition solution I would highly recommend getting a dedicated USB DAQ device such as the NI USB-6251. In addition to being natively USB 2.0 compatible it is quite a bit more capable than the DAQCard 6062E.
Once again thanks for contacting NI.
-John Sullivan
Problem Solver
(4,283 Views)
My new computer doesn't have a PCMCIA port for my 6062E DAQCard.  Can you recommend a converter so I can use a port that it does have?  (EC, SC, USB, eSATA, or SD)  Thanks!
(3,981 Views)
As 'Knights Who Say NI' says in the post above, we still do not sell nor support any PCMCIA-to-{ExpressCard, SmartCard, USB, eSATA, SD} adapters.
Further, since I expect this is a newer laptop, even if you had a PCMCIA-ExpressCard or PCMCIA-USB adapter that did work, note that DAQmx only supports DAQCards on 32-bit Windows Vista/7 and not on 64-bit.
I would recommend a native USB device instead, such as the USB-6341.
(3,963 Views)
