USB5133
I am using the attached vi to collect data.
Sampling frequency is 100MHz. Using analog edge trigger. The signal is pulse waveform.
Every pulse need to collect 512 points.
I made a test, using a signal generator generate a 100kHz sine wave. If the 5133 is fast enough, it should collect 100k wave/S. But it can only collect around 140wave/S. I tried to make wave collection shorter as 256 points. But it still only can collect around 140 wave/S, too slow.
Any suggestion? (my pc is quite new)
(3,193 Views)
Try playing with the min record lenght on the 2nd subvi of your vi.
Yik
Kudos and Accepted as Solution are welcome!
(3,073 Views)
