controlling of while loop
hi
 I m acquiring data with DAQ data assistance and its while loop.
 My problem is that I m not able to control while loop through Pulse timing like 200 ON time 800 OFF time or Continuous time duration like 100 second.Please give me some suggestion.How can i make such a system?
My second question is I want to convert voltage signal into some standard unit like BAR through fourth order equation.I m trying this thing with array.Is there is any other method that i can use and one more thing the constant of fourth order equation i have to made user define i.e on interface.
Please suggest me this is my first project .
Thanks and Regard
 Saurabh Agrawal
(3,049 Views)
Give a more detail decription about your problem.  Not sure am I following you.
Yik
Kudos and Accepted as Solution are welcome!
(2,934 Views)
