Voltages
hello,
I'm using signal express for recording some measurements and when acquiring signals I can chose between custom excitation voltage and only voltage - what is the difference? what excitation is applied when I do not specify the excitation?
R.v.Bock
(2,987 Views)
What DAQ device are you using?
Yik
Kudos and Accepted as Solution are welcome!
(2,877 Views)
