USing PCI-6029 to generate a square wave with a variable frequency
I am trying to use the PCI-6029 to commande a step motor.
I need for a simulation to generate a square wave with a  frequency variant between 0 and 10 kHz.
Can some one please help me figure out how to do these  with my pci-6029 .
I appreciate the help,
thanks
 Jean-claude
(continuous pulse) at 10 MHz, this will be an output of the DAQ Card and will be fed into my circuit.
I also have an output line in my circuit that is a square wave (perhaps lower voltage level) at 10 MHz and I would like to measure its level using my DAQ board.
and it's frequency.
(3,293 Views)
Hi Jean-claude,
I do some search for PCI-6029 card and I didn't found this on NI website and MAX.
Are you sure it's a PCI-6029?
Regards
Yann C.
France
(3,278 Views)
Accepted by topic author jean-claude
               I Yann C.
    Sorry, it isn't a PCI 6029 but a PCI 6024.
But I found the solution of my problem yesterday.
Here it is.
    Regards
                                  Jean claude
(3,270 Views)
