Unable to output 2 sine waves simultaneously usind DAQ PCI6251/SCB68 card through AO 0 and AO1 outputs
my application is to generate 2 sien waves and simultaneously output through
DAQ PCI6251 and SCB68 AO ports 0 and 1. I am not able to output it through
the AO ports although the program is running. Attached please find the VI program
for that and please let me know where are the issues
(3,224 Views)
blank_page
Do you see any error message or does the program simply run without any issues? How do you determine if any voltage is being output? Have you checked both the o/p channels separately?
Try running the following example and check if both the channels do have an issue when it comes to simultaneous updating:
(3,202 Views)
