Unexpected stop of DAQ continuous sampling
When I performs continuous sampling task in the test panel, the task works well at first, but can't read any data after a while. (The duration is not fixed) Then, if I press the stop button, the device (NI-USB 6229) will restart by itself. I don't know why.Smiley Sad
Thanks for your help!
Bob.
(2,158 Views)
The task panel of MAX is mainly used for checking if your acquisition/generation works. Perhaps the buffer gets full after a few seconds.
Try to limi the number of samples to a high value, e.g. 100k.
(2,136 Views)
